[GRASSLIST:659] WIND file corrupted during r.proj import
I ran r.proj within a UTM zone20 Location to import a Lat-Long WGS84 raster,
and ever since my projection info has been messed up. Here is the output
from g.proj -p:
GRASS 6.1.cvs (Cheticamp):~/Projects/Cheticamp/PERMANENT > g.proj -p
-PROJ_INFO-------------------------------------------------
proj : utm
ellps : wgs84
a : 6378137.0000000000
es : 0.0066943800
zone : 20
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1.0
And from DEFAULT_WIND:
GRASS 6.1.cvs (Cheticamp):~/Projects/Cheticamp/PERMANENT > more DEFAULT_WIND
proj: 1
zone: 20
north: 5315984.91222247
south: 5002065.13022186
east: 833130
west: 486750
cols: 34638
rows: 31392
e-w resol: 10
n-s resol: 9.99999306
Lastly, my WIND file:GRASS 6.1.cvs
(Cheticamp):~/Projects/Cheticamp/PERMANENT > more WIND
proj: 1
zone: 20
north: 46.7892
south: 46.6416
east: -61.008
west: -61.1568
cols: 2
rows: 2
e-w resol: 0.0744
n-s resol: 0.0738
top: 1
bottom: 0
cols3: 2
rows3: 2
depths: 1
e-w resol3: 0.0744
n-s resol3: 0.0738
t-b resol: 1
This seems to be the reason why v.in.ogr is failing to import data that I
know is in UTM20, WGS84 - I have to use the -o flag to get anything
imported.
Setting the region to that of an existing raster/vector does not overwrite
the WIND file as I thought it might - I'm still stuck with a UTM AND LatLong
Location, it would seem.
Any solutions on how to get my proj info set back to UTM20?
~ Eric.
