[GRASSLIST:660] off topic: backing up huge mapsets
I know this is off topic but probably some of you had experienced this problem as well. I have a very large mapset (19 GB) which is not compressed by using bz2 (the final tar.bz2 file was 17.2 GB). I have a backup of this mapset on an USB hard disk but I would like to create another copy in a couple of double layer DVDs (I don’t want to take any chances with the data that I have). Does someone know how to create three smaller files which I can later burn on separate DVDs?
thanks,
Jaime
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
don't want to take any chances with the data that I have). Does
If you just want to chop the file up in a way that you can put them
together later to play with it (each segment won't be usable as-is),
then use either the Unix "split" command or the "dd" command. You
can specify how many bytes to split at. See the man pages for each.
Curt, WE7U. APRS Client Comparisons: http://www.eskimo.com/~archer
"Lotto: A tax on people who are bad at math." -- unknown
"Windows: Microsoft's tax on computer illiterates." -- WE7U
"The world DOES revolve around me: I picked the coordinate system!"
tar --help:
  Device selection and switching:
   -f, --file=ARCHIVE use archive file or device ARCHIVE
       --force-local archive file is local even if has a colon
   -F, --info-script=NAME, --new-volume-script=NAME
                              run script at end of each tape (implies -M)
   -L, --tape-length=NUMBER change tape after writing NUMBER x 1024 bytes
   -M, --multi-volume create/list/extract multi-volume archive
       --rmt-command=COMMAND use given rmt COMMAND instead of rmt
       --rsh-command=COMMAND use remote COMMAND instead of rsh
       --volno-file=FILE use/update the volume number in FILE
... so options -L and -M should be what you are looking for?
Benjamin
I know this is off topic but probably some of you had experienced this problem as well. I have a very large mapset (19 GB) which is not compressed by using bz2 (the final tar.bz2 file was 17.2 GB). I have a backup of this mapset on an USB hard disk but I would like to create another copy in a couple of double layer DVDs (I don't want to take any chances with the data that I have). Does someone know how to create three smaller files which I can later burn on separate DVDs?
thanks,
Jaime
__________________________________________________
Correo Yahoo!
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeo-Information Science)
Institut für Ur- und Frühgeschichte
(Institute of Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
If you are on windows then have a look for 7zip http://www.7-zip.org/
cheers
Wolfgang
Benjamin Ducke schrieb:
tar --help:
Benjamin
thanks,
Jaime
Correo Yahoo!
