Probably an obvious question, but I can not find the answer in the help files and other references.
How do I export a vector table directly to a text file from within Grass?
Thanks in advance for your help,
Sander.
Dr. Sander P. Oom
Animal, Plant and Environmental Sciences,
University of the Witwatersrand
Private Bag 3, Wits 2050, South Africa
Tel (work) +27 (0)11 717 64 04
Tel (home) +27 (0)18 297 44 51
Fax +27 (0)18 299 24 64
Email sander@oomvanlieshout.net
Web www.oomvanlieshout.net/sander
> Grass?
do you mean database table?
echo "select * from your_vector_file "| db.select -c > text_file.txt
or via ooffice calc, if you want just to edit it and you are not
familiar with SQL
see also v.db.select; v.to.db; v.out.ascii.db from the Add-on section of
the wiki if you want associated coordinates; v.to.points+v.out.ascii; and
the little dbview application (google).
