[GRASSLIST:6624] Grass GIS and Fragstats on Linux!
Dear Fragstats and Grass GIS users,
To my pleasant surprise I have successfully run Fragstats on a Linux machine in conjunction with my Grass GIS database.
I tried the landscape index tools r.le within Grass, but ran into several problems (see earlier posts on the Grass mailing list). Than I started looking for an alternative. Fragstats is a powerful and well tested program, but it is only available for Windows.
However, when running the Fragstats setup program using CrossOver Office on my Linux machine, the installer finished without any errors! I have tried several options and methods and have not seen the program crash yet! I guess the success is a result of the combination of the little dependency of Fragstats on odd windows dll's and the progress made in the Wine project, the basis for CrossOver Office. I have not tested Fragstats on Wine.
Below you find the Grass code to prepare your data for Fragstats. I used the Albers Equal Area projection to prepare my rasters. Using sed (Linux utility) I removed the header from the exported ascii file. Fragstats only wants the points. I put the header content in a file called 'asc_header_aea.txt' so I could paste it back in later, as Fragstats returns exactly the same grid of points. Fragstats creates a new folder with an ascii grid (no header nor an extension!) for each index calculated, so I wrote a loop to go through the files, add the header and read the result into Grass. Then I queried the raster with a points vector and exported the results to a text file.
Hope this is helpful for other Grass/Linux users!
Sander.
## Export to ASCII and prepare file for Fragstats
dirOut=/grassdata/output
rastIn="nlc31"
rastOut=$dirOut/nlc31_aea
r.out.arc input=$rastIn output=$rastOut.asc dp=6
## remove header and replace -9999 with 9999
cd $dirOut
sed '1,6d' < nlc31_aea.asc > nlc31_aea_frgs.asc
## Import Fragstats results
## query with sa10min
## export to text file for analysis in R
map=nlc31
   for index in MSIDI MSIEI SHDI SHEI SIDI SIEI ; do
     ## set resolution to 1 km; projection in meters!
     g.region res=1000
     ## Add header to fragstats result and paste into ASCII file
     frgsIn=/grassdata/output/${map:-nlc31}_aea_frgs.asc_MW1/${index:-MSIDI}
     hdrAEA=/grassdata/output/asc_header_aea.txt
     ascOut=/grassdata/output/${map:-nlc31}_aea_${index:-MSIDI}.asc
     echo $frgsIn
     cat $hdrAEA $frgsIn > $ascOut
     ## Import ASCII
     ascIn=$ascOut
     rastOut=${map:-nlc31}${index:-MSIDI}
     r.in.arc input=$ascIn output=$rastOut
     ## Query raster with sa10min and export to file
     vectTmp=tmp
     g.remove vect=$vectTmp
     g.copy vect=sa10min,$vectTmp
     dirDBF="/grassdata/sa-aea/macwits/dbf/"
     db.columns table=$vectTmp driver=dbf database=$dirDBF
     ## Add new column to attribute table
     echo "ALTER TABLE $vectTmp ADD COLUMN value double " | db.execute
     ## Query raster with vector
     v.what.rast vect=$vectTmp rast=$rastOut col=value
     dirFrags=/data1/gis/fragstats/macwits/output
     textOut=$dirFrags/${map:-nlc31}_sa10min_${index:-MSIDI}.txt
     echo " SELECT * FROM $vectTmp " | db.select fs="," > $textOut
   done
Dr. Sander P. Oom
Animal, Plant and Environmental Sciences,
University of the Witwatersrand
Private Bag 3, Wits 2050, South Africa
Tel (work) +27 (0)11 717 64 04
Tel (home) +27 (0)18 297 44 51
Fax +27 (0)18 299 24 64
Email sander@oomvanlieshout.net
Web www.oomvanlieshout.net/sander
Good new - thanks Sander.
However, AFAIK Crossover Office is not free software. It would therefore be
important to check if Fragstats works under wine.
In the long term, we should see if it's possible to either port Fragstats
under linux, integrate it more closely with grass, and/or rewrite r.le.
All the best.
pc
At 10:55, martedì 26 aprile 2005, Sander Oom has probably written:
Fragstats on Wine.
Sander.
Paolo Cavallini
cavallini@faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
I don't have any data to try any serious work, but it installs and executes
perfectly with wine version 20050310 on Debian GNU/Linux and I can open all
the subwindows...
If someone has some data, I am willing to test...
Moritz
All the best.
pc
Fragstats on Wine.
Sander.
Paolo Cavallini
Hi Paolo,
Fair point about CrossOver Office. I tried Wine for quite some time, but found it to fiddly. I find CrossOver worth the money as it makes running Windows software a lot simpler. Moreover, not all things have to be free. Paying for CrossOver Office directly contributes to the development of Wine.
I will send Moritz a test grid and see how Fragstats works on Wine!
I agree that in the long run something closer to Grass is preferable! Fragstats and r.le are options, but it might also be worthwhile to contact the people behind IAN and its predecessor Apack (http://landscape.forest.wisc.edu/projects/, bdezonia@wisc.edu). Not sure where the bets 'fit' is between Grass and R, but heavy duty landscape indices work should probably be done in Grass. However there is a great push for spatial classes in R!
Nice to see common goals and much progress!
Sander.
However, AFAIK Crossover Office is not free software. It would therefore be important to check if Fragstats works under wine.
In the long term, we should see if it's possible to either port Fragstats under linux, integrate it more closely with grass, and/or rewrite r.le.
All the best.
pc
Fragstats on Wine.
Sander.
Dr. Sander P. Oom
