[GRASSLIST:6675] 3D vector support
I would like to insert a cave into a NVIZ view. The idea is to render the DMR
surface transparent so that the cave can be seen through it. That is why I
needed 3D vector support and decided to take advantage of the OpenDWG library.
I downloaded the OpenDWG toolkit, but the instructions are quite complicated.
In the v.in.dwg html help file it is written:
... Then unpack library and copy to this directory: ad2.a ad2.h odio.h
adinit.dat and compile this module.
Which is 'this' directory? I got the html from the internet. Where do I find
the mentioned files? If I search through the uncompressed library files I can
not find the mentioned files.
Any help appreciated,
Miha Staut
Send instant messages to your online friends http://uk.messenger.yahoo.com
Miha Staut wrote:
Any help appreciated, Miha Staut
You need a toolkit, for example ad27linx.tar, unpack in a directory, e.g. /home/usr1/opendwg27 and use GRASS configure options
--with-opendwg
--with-opendwg-includes=/home/usr1/opendwg27
--with-opendwg-libs=/home/usr1/opendwg27
Radim
