[GRASSLIST:6687] Re: Error in startup script: ps.map:
  > GDAL is a mandatory dependency for GRASS 6.x. You can obtain it from:
  http://www.gdal.org/
If you already have it, and it's installed in /usr/local/lib, check
that /usr/local/lib is listed in /etc/ld.so.conf; if it isn't, add it
then run "ldconfig".
I only get
GRASS 6.0.0 (abbubu):/etc > Error in startup script: couldn't execute "ps.map": no such file or directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 32)
    invoked from within
"main $argc $argv"
    (file "/usr/lib/grass/etc/dm/d.m.tcl" line 894)
no mention of gdal but GRASS isn't working anyway. anyone who got the same problem?
Stefano Costa
Visita il mio sito: http://www.iosa.it - Software Open Source per l'Archeologia
GnuPG Key ID: 1024D/0xD0D30245
Jabber: archeosteko@jabber.linux.it
Per favore non mandarmi allegati Word o PowerPoint.
Puoi utilizzare formati come pdf, html o testo semplice.
Per maggiori informazioni visita:http://www.fsf.org/philosophy/no-word-attachments.it.html
