Has anyone had any luck getting GRASS 6.1 to run under Tiger? I've reinstalled everything following the upgrade (archive and install) but haven't been able to get the 19 April CVS binary working. I can go into the .app package and open the startup screen (where you choose the location), but it fails to launch GRASS from there (i.e. no GRASS prompt in the shell). Any tips or just wait for an update? Thanks.
Tim
________________________________________________
Tim De Chant
University of California, Berkeley
Environmental Science, Policy, and Management
137 Mulford Hall #3114
Berkeley, CA 94720-3114
Phone: (510) 643-3910
Not yet Tim. I am waiting for a copy of Tiger server to show up in the mail. When it arrives (probably next week) I will be doing a clean install and re-build of all grass and mapserver bits and pieces. When I have something to report, I'll let you know,
Kirk
Tim
Tim De Chant
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers@umn.edu
tel: 612.625.2261
fax: 612.625.5212
Hi Tim
Has anyone had any luck getting GRASS 6.1 to run under Tiger? I’ve reinstalled everything following the upgrade (archive and install) but haven’t been able to get the 19 April CVS binary working. I can go into the .app package and open the startup screen (where you choose the location), but it fails to launch GRASS from there (i.e. no GRASS prompt in the shell). Any tips or just wait for an update?
Thanks.
Tim
I have not Tiger but you test this change.
Exit from Grass and X11.
You open grass61cvs (Ctrl+Mouse clic and Show Package Contents)
Make a copy of “grass61cvs.app/Contents/Resources/Scripts/script.scpt” file.
Double clic on grass61cvs.app/Contents/Resources/Scripts/script.scpt file and it is opened from Script Editor application.
You see the source of Apple Script code. At the bottom you see:
if uscita = “uscita” then
set the totale to unixpathgrass & “Contents/Resources/” & grassversionreal & “/” & grass & mode
tell application “X11”
activate
if osxaqua = “1” then
set results to do shell script “cd ~; DISPLAY=:0.0; export DISPLAY; PATH=$PATH:/usr/bin; export PATH; osxaqua=” & osxaqua & “; export osxaqua; /usr/X11R6/bin/xterm -geometry 80x30 -e " & totale & " > /dev/null 2>&1 &”
else
set results to do shell script “cd ~; DISPLAY=:0.0; export DISPLAY; PATH=$PATH:/usr/bin; export PATH;” & “/usr/X11R6/bin/xterm -geometry 80x30 -e " & totale & " > /dev/null 2>&1 &”
end if
end tell
quit
end if
end «event coVScliI»
property ASDScriptUniqueIdentifier : “script.applescript”
You add 3 rows (after the second row):
tell application “Finder”
launch application “X11”
end tell
activate
else
end if
end tell
quit
end if
Save this file.
Close X11 and Grass.
Double clic on grass61cvs application and press START.
If this change is OK it’s also good for grass60 application.
Bye
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
________________________________________________________________________
Thanks, Lorenzo. I won't be able to try this until tonight, but I'll post my results when I do.
Tim
Tim De Chant
On May 2, 2005, at 2:34 AM, Lorenzo Moretti wrote:
Hi Tim
Thanks.
Tim
Make a copy of "grass61cvs.app/Contents/Resources/Scripts/script.scpt" file.
if uscita = "uscita" then
set the totale to unixpathgrass & "Contents/Resources/" & grassversionreal & "/" & grass & mode
tell application "X11"
activate
if osxaqua = "1" then
set results to do shell script "cd ~; DISPLAY=:0.0; export DISPLAY; PATH=$PATH:/usr/bin; export PATH; osxaqua=" & osxaqua & "; export osxaqua; /usr/X11R6/bin/xterm -geometry 80x30 -e " & totale & " > /dev/null 2>&1 &"
else
set results to do shell script "cd ~; DISPLAY=:0.0; export DISPLAY; PATH=$PATH:/usr/bin; export PATH;" & "/usr/X11R6/bin/xterm -geometry 80x30 -e " & totale & " > /dev/null 2>&1 &"
end if
end tell
quit
end if
property ASDScriptUniqueIdentifier : "script.applescript"
tell application "Finder"
launch application "X11"
end tell
activate
else
end if
end tell
quit
end if
Save this file.
If this change is OK it's also good for grass60 application.
Bye
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Hi all
In the site there are two very small patch (6 kb) for working with grass 5.4 and grass 6.0 in the new Mac OS X 10.4 (Tiger).
http://wwwamb.bologna.enea.it/forgrass/download.htm
This patch is good for ALL MAC OS X: 10.2.8 and higher.
Read the README file for installing the patch.
Future 6.1.cvs version will include this patch.
Thanks to Renato Henriques for the report
Bye
|| Lorenzo Moretti e-mail: lorenzo.moretti@bologna.enea.it ||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/ || | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
Download GRASS for MAC OS X: http://wwwamb.bologna.enea.it/forgrass/
On May 3, 2005, at 8:31 AM, Lorenzo Moretti wrote:
Hi all
Lorenzo,
Will you let the list know when this patch goes into cvs?
Kirk
Bye
-- ________________________________________________________________________
Kirk R. Wythers
tel: 612.625.2261
fax: 612.625.5212
