[GRASSLIST:6711] Re: problem with database name
Dear Adam,
First of all, please do not send such requests to my personal mail, but to the
GRASS-Users mailing list (http://grass.itc.it/community/support.php#int_list)
to which I cc this response.
Since you work with MS Windows, the winGRASS list would be even better:
http://grass.itc.it/platforms/wingrass.html
On Thu, May 5, 2005 11:46, Adam Podlaha (UK) said:
Dear Mr. Lennert,
I have following problem during entering the database patch in during
the start up. I downloaded the sample data (spearman) and I put it in
c:\data\GRASSDATA but after I enter this patch to the window it shows
me, that it doesn't exist.
Could you please be more explicit: what window and what do you mean by "patch"
? How does "it" show that "it" doesn't exist ? Please give your exact
procedure and the exact error message.
Could you please tell me what exactly I
should write into the window? The default after I start GRASS is
/home/Administrator. The second problem is, that I have installed GRASS
as administrator, but I can not start it as another user. Do you know
why?
I do not work with MS Windows, so I have no idea how to this. I suppose the
administrator has to give users the right to use the program.
But there are others on the above-mentioned lists who can certainly help you
better than I can.
Moritz
