I'm creating some ps.maps for display and aparently
the colors on the colortable are faded, compared to
the colors on the map. I used the options
rast <rast name>
colortable
where 6.8 1
width 0.5
height 10
cols 1
color black
Also, I still haven't figured out yet what those
numbers means, are they in inches?
Thanks
Daniel
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month! http://sbc.yahoo.com
That may be one of two things:
1) poor color matching between your printer and your monitor. Color
combinations that look terrible on the monitor often look great on the
printer and vice versa.
2) ps.map's color legends are slightly transparent, when you place them
over a colored part of the map, the colors might be slightly polluted.
I'm not sure if this happens in a printed hard copy (doesn't seem to be
noticeable), or only when you view it with an on-screen viewer (gv). Try
zooming way in with gv with a legend placed over an uneven background to
see what I mean.
I used the options
rast <rast name>
colortable
where 6.8 1
width 0.5
height 10
cols 1
color black
don't forget the 'end'
They are in inches from the corner of the page. (pick one
hint: PostScript units are 1/72 of an inch. Use the x,y mouse position
from GhostView (gv) and a hand calculator to take the trial and error
out of object placement. You may need to use (max_y - y)/72 to get
the right number.
factoid: That makes a font size of "10" have a height of 10/72 of an
inch. If you want 1 inch tall text on the printed page, use a font size
of 72.
