[GRASSLIST:6730] symbols and map units
I am trying to create a symbol and display it in scale corresponding
with map units.
E.g.: a map created with ps.map (scale 1:1000), I would like to display points
radius: 0.5mm on the map -> so 0.5m. I am completely confused with BOX.
VERSION 1.0
BOX -0.5 -0.5 0.5 0.5
POLYGON
  RING
    FCOLOR 0 0 0
    ARC 0 0 0.5 360 0 C
  END
END
I have read about symbols at
  http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassProgrammingHowto#Display_Symbols
but it didn't help me...
Based on this text:
when I use size=1 -> the radius should be 0.5 (map units??)
or for size=100 -> radius=50 ... but when I try to create map using ps.map I get wrong result
(smaller circle...).
Can anyone tell me why I am wrong??
Thanks a lot,
Martin
Martin Landa <landa@gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
with map units.
perhaps try v.buffer and ps.map's vareas.
Hamish
> with map units.
yes, but I would like to display special symbols (for cadastral maps), not only
circles... I don't understand relation between BOX (larger side) and symbol
scaling (in map units). So I am not sure if it is possible to find relation
between size of symbols and map units...
BTW, how to display part of circle (ARC) (90deg->270deg clockwise).
    ARC 0.25 0.75 0.75 90 270 works
    I need ARC 0.25 0.75 0.75 90 270 C (or ARC 0.25 0.75 0.75 270 90) -> I get only line...
Martin
> > corresponding with map units.
not only circles... I don't understand relation between BOX (larger
side) and symbol scaling (in map units). So I am not sure if it is
possible to find relation between size of symbols and map units...
the icons are not tied to map units. zoom way in or way out they stay
the same size relative to the display monitor.
some hacking of the ps.map code might change this for you.
also try the embedded postscript (eps) symbol support in ps.map.
maybe someone else knows a solution.
If you try and draw the arc backwards then only the start/end points are
connected. Switching the order of the angles or adding "C" should make
it draw.
are you trying for something like this?
____
\__/
ARC 7 7 3 180 360
So just switch the order of the numbers or add a "C" to the end of the
line.
that "ARC x y r 360 180" draws only a line is probably a bug?
Note degrees are polar theta not navigational, i.e. 0 is east and values
increase counter-clockwise from there. Reducing the angle from a full
circle does not make it draw like a pacman but rather with a straight
chord-line from the start/end points on the circle as defined by the two
angles.
Hamish
with map units.
In GRASS 5.4's ps.map there is the wonderful "sites" command with the size_att
option, but this doesn't exist anymore since sites are vectors now.
In GRASS 6.0 you could also (in addition to Hamish' solution) create eps
symbols that are already scaled (with R for example) and then use the vpoints
command (with $) to put them onto your map.
Or you write a script (or do it by hand if you don't have many symbols) which
creates a ps.map input file with a vpoints command for every symbol using the
"cats" and "size" options.
Moritz
____
\__/
ARC 7 7 3 180 360
line.
Sorry, maybe I don't fully understand...
    ARC 0.25 0.75 0.75 180 360 or ARC 0.25 0.75 0.75 360 180 C
draws
    ____
    \__/
but ARC 0.25 0.75 0.75 360 180 or ARC 0.25 0.75 0.75 180 360 C
draws
   ____
instead of
   __
  /__\
so it is a bug?? I can try to fix it...
  Martin
