[GRASSLIST:6740] Re: GRASS and QGIS
I ment it might be easier to get things correctly configured under linux..
Geir
-----Original Message-----
[mailto:owner-GRASSLIST@baylor.edu] On Behalf Of Systad, Geir
Sent: Monday, May 09, 2005 12:16 PM
To: holl@gdf-hannover.de
Cc: grasslist@baylor.edu
Subject: [GRASSLIST:6738] Re: GRASS and QGIS
Thanks, Stephan-
To compile qgis under cygwin/windows might be a solution, so
I will look into it in my linux system instead.
And I guess it might be just as easy to do the neccecary work
by command line in grass, and use qgis as a viewer/layout tool?
Cheers, Geir
> From: owner-GRASSLIST@baylor.edu
> [mailto:owner-GRASSLIST@baylor.edu] On Behalf Of Stephan Holl
> Sent: Monday, May 09, 2005 10:49 AM
> To:
> Subject: [GRASSLIST:6735] Re: GRASS and QGIS
> Hello Geir,
> On Mon, 9 May 2005 10:25:19 +0200 geir.systad@nina.no wrote:
> > Hei-
> > I have started qgis within grass 6.1.cvs (Windows-Cygwin). I know
> > there is a grass toolbox somewhere, but the only reference to the
> > toolbox I can find, is
http://wiki.qgis.org/qgiswiki/Adding_New_Tools_to_the_GRASS_To
olbox.
> Can anyone give me the right references/instructions/directions for
> installing the grass toolbox in qgis?
> Sincerely,
> Geir Systad
AFAIK there is no windows port for the necessary GRASS-Plugin
for QGIS yet. So you need to compile QGIS with the needed
GRASS_Plugin by your own.
Please correct me if I am wrong (I am not up-to-date
regarding to windows stuff...)
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office (TCH) - Vahrenwalder Straße 7 - D-30165 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511-9357560 - Fax: ++49-(0)511-9357100
