[GRASSLIST:6893] v.proj problem
Hi to all,
I have reprojected 3d vector points from wgs84 lat long location to
utm33:
-in the UTM 33 location:
v.proj input=data_wgs84 output=data_utm33 location=WGS_84_latlong mapset=PERMANENT
I got the following error:
Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
Output Projection Parameters: +proj=utm +zone=33 +a=6378388 +rf=297
+no_defs +towgs84=-87.000000,-98.000000,-121.000000
Output Unit Factor: 1
Creating vector file...
pj_transform() failed
cause: geocentric transformation missing z or ellps
Error in pj_do_transform
GRASS 6.0.0 (umbmar):~ >
can someone help?
Francesco
p.s.
I did v.proj transformations some other times from the same location
into the utm33 location, but it is the first time that this error
occurred.
As far as I can remember, v.proj in 6.x has a "feature" that it interprets the z co-ordinate of 3-D vectors as ellipsoidal height and tries to convert it as part of the re-projection. In most cases this interpretation will probably not be correct. There really should be a command-line flag to say 'interpret z co-ordinate as ellipsoidal height and transform accordingly'.
Normally you would expect the z co-ordinate to remain unchanged, the way I'm looking at it. I could be missing something though.
Not sure if this is related to you problem but thought I should mention it.
Paul
On Thu, 26 May 2005, Francesco Mirabella wrote:
Hi to all,
utm33:
can someone help?
Francesco
p.s.
occurred.
I found out that I had a problem only in one vector points map, not in
the others.
The problem was the in the originally imported ascii (v.in.ascii) as
some points did not have points (e.g. longitude was 125674 rather than
12.5674)
When I imported the ascii (v.in.ascii) I did not get any error
(shouldn't I ???) and all the points were imported.
The problem came out only when I re-projected to another location but
the error message was missleading (I think) as it was about:
>+rf=298.257223563
Hope this helps....
cheers
Francesco
it.
Paul
>Hi to all,
>utm33:
>mapset=PERMANENT
>can someone help?
>Francesco
>p.s.
>occurred.
