> > was trying to export a GRASS raster with r.out.gdal and had the
> > following error:
> > r.out.gdal in=amox out=amox format=GTiff type=Float32
> > Writing format: GTiff
> > Writing type: Float32
> > Failed to process SRS definition: 'PROJCS["UTM
> > I am using GRASS6.1-cvs and GDAL 1.2.6, both installed from source
This happened with this morning's CVS version...
Yes, confirmed with Spearfish. The quoting bug still lives.
GRASS 6.1> r.out.gdal in=elevation.10m out=elev format=GTiff type=Float32
By changing the top line of the script to
#!/bin/sh -x
and changing the PROJECTION line to (just for clarity; same result)
- PROJECTION="-a_srs '${WKT}'"
+ PROJECTION="-a_srs ${WKT}"
we see that the failing command is:
gdal_translate -of $FORMAT -ot $TYPE $PROJECTION $CREATEKEY $METAKEY \
$CELLHD $OUTPUT
which expands to:
gdal_translate -of GTiff -ot Float32 -a_srs 'PROJCS["UTM' Zone 13, Northern 'Hemisphere",GEOGCS["clark66",DATUM["North_American_Datum_1927",SPHEROID["clark66",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["meter",1]]' /home/hamish/grassdata/spearfish57/PERMANENT/cellhd/elevation.10m elev
It is adding 'single quotes' around things with spaces in the WKT such
as "WKT Zone 13". How can this be stopped?
Hamish
