I need to import netcdf files into GRASS 6.0.0. I successfully built GRASS 6.0.0 with gdal support (and previously built gdal with netcdf support), but when I try to import the netcdf file, GRASS tells me it's an unsupported format. The r.in.gdal -f option confirms that netcdf is not supported as it is available in GRASS. I don't understand.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
understand.
does this list it?
gdalinfo --formats
if so it should work with GRASS too, but make sure you don't have
multiple GDAL libraries installed, GRASS might be picking up the one
without netcdf support.
Quick solution:
convert to a GeoTIFF or something with 'gdal_translate' and load that.
r.in.gdal -f in=foo out=bar | grep -i cdf
GMT (rw): GMT NetCDF Grid Format
netCDF (ro): network Common Data Format
when I run 'r.in.gdal -f in=foo out=bar | grep -i cdf
So, your best guess is that a gdal lib is being picked up without netcdf support. I'm not sure how this can be since I built all the libs. Due to local admin restrictions I had to put the gdal libs (and proj libs, etc.) in with the GRASS libs. How can I be sure that the gdal lib correctly built with netcdf support?
I do have one question, when building gdal, am I suppose to set the flag for GRASS support? I tried that once and got some error, so I *maybe* mistakenly thought that I should not do that.
Tom
understand.
does this list it?
gdalinfo --formats
Quick solution:
Hamish
Thomas E Adams
I guess gdal didn't actually build with it then.
support?
gdalinfo --formats
gdal-config --dep-libs
# and look for -lnetcdf
gdal-config --formats
# should be same as gdalinfo
That shouldn't have anything to do with it. GRASS support in GDAL is for
reading GRASS maps outside of GRASS. e.g. from QGIS, Mapserver, etc.
Note GRASS's r.out.gdal needs the GDAL-GRASS driver to work AFAIK.
In the past if you wanted to do this, you used to have to build GDAL
before GRASS without the GRASS driver, and then build GDAL again after
GRASS was made with the GRASS driver enabled.
The latest versions of GDAL builds the GRASS driver as a plugin, and you
can safely build the GRASS driver at any point.
