[GRASSLIST:6935] how to get a polygon in ascii ...
Not sure exactly how to ask.
What i need is a list of vector end points that I can use
to create a polygon from a set of lat/lon points.
In detail I want to be able to create a MySQL
spatial polygon of the Conterminous United States
I've played around with v.out.ascii but have not
had much success.
Thanks in advance,
-pete
had much success.
v.out.ascii's default action is to only output points. You have to use
'v.out.ascii format=standard' or first change line/boundary vertices to
points with v.to.points.
Hamish
