[GRASSLIST:7] d.rbg still crashes...
I've just installed the cygwin grass5.0.2 from the download site and tried
to display a composite image using d.rgb and the display window still
crashes when I try to run the command. Since I've never tried to fix someone
else's GRASS code, how should I go about getting this fixed?
Jeff.
