[GRASSLIST:703] tiger2k questions (listproc is driving me nuts!)
Ok, I ran v.in.ogr.
I used the directory containing the tiger data files as the OGR datasource
name.
The output vector name was a directory. It tried to create database
tables. I don't have a postgress schema created yet, and it failed trying
to create a table with a / in it.
So, I just made the output vector a file name. The process is running
now, but I am getting a lot of output saying:
WARNING: Feature without geometry
I think I'm doing something wrong! :smiley:
What does this mean? I am extracting the Polygon layer.
-M
p.s. the listproc server rejected this message twice because it had words
that looked like a command!
mdeneen@japple.org wrote:
Ok, I ran v.in.ogr.
I used the directory containing the tiger data files as the OGR datasource name.
M,
OGR's data model for Tiger is closely tied to the underlying tiger data model.
One downside of that is that the polygon layer consists of features with
the polygons attributes but no geometries. The geometries have to be
built up from chains from the CompleteChain layer associated to the polygons
using the contents of the PolyChainLink layer.
It might be an interesting test of GRASS 5.1 to see if it is possible to import
the raw attribute layers Polygon, and PolyChainLink and the CompleteChain
line geometry layer, and use the information to build up the polygon
geometries.
However, practically speaking, I imagine it is better to do all this as a
pre-processing step before bring it into GRASS. I have attached a Python
script that be used with GDAL/OGR to build a shapefile with the polygon
geometries. If you have a full GDAL/OGR build installed you should be
able to use it to build the polygons. If you have further questions about
getting the python script working it should likely be taken off this list
since it isn't really a GRASS issue.
Ideally the OGR TIGER/Line driver should do this for you (at least optionally)
but I have not implemented that.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
(attachments)
tigerpoly.py (6.66 KB)
model. One downside of that is that the polygon layer consists of features
with the polygons attributes but no geometries.
It is not downside but very important advantage for GRASS :slight_smile:
polygons using the contents of the PolyChainLink layer.
import the raw attribute layers Polygon, and PolyChainLink and the
CompleteChain line geometry layer, and use the information to build up the
polygon geometries.
Yes, it is possible and much better than to import polygon rings, what
is the case for other OGR layers. Unfortunately it needs to use more
GRASS commands to get the result. Here is commented example how to
import Tiger data (Postgres driver necessary):
# Import lines (boundaries+lines)
v.in.ogr dsn=input/2000/56015/ layer=CompleteChain output=t56015_CompleteChain
# Import centroids
v.in.ogr dsn=input/2000/56015/ layer=PIP output=t56015_PIP
# Import table containing info about left/right side of boundaries
v.in.ogr dsn=input/2000/56015/ layer=PolyChainLink output=t56015_PolyChainLink
# Create a new table containing lines' cats and left/right info
# (in psql)
create table t56015_cp as select t56015_completechain.cat,
t56015_completechain.tlid, polyidl, polyidr from t56015_completechain, t56015_polychainlink
where t56015_completechain.tlid = t56015_polychainlink.tlid;
# Link the new table to lines
v.db.connect -o map=t56015_CompleteChain driver=pg database=tiger table=t56015_cp key=cat
# Extract boundaries (lines representing boundaries)
v.extract -t input=t56015_CompleteChain output=t56015_boundary_cat where="polyidl <> polyidr"
# Patch boundaries (so far type line) and centroids (still type point)
v.patch input=t56015_boundary,t56015_PIP output=t56015_patch
# Change lines to boundaries and points to centroids (like v.line2area)
v.type input=t56015_patch output=t56015 type=line,boundary,point,centroid
Note that I had problems with Tiger2002 and I have done some changes to
GRASS (e.g. v.in.ogr writes attributes for features without geometry now).
It is not very practical to use 8 commands instead of 1. As it is
now, it cannot be too much simplified and the solution within GRASS
would be probably v.in.tiger based on OGR, but that is what
we wanted to avoid and to have only one import module, see below.
optionally) but I have not implemented that.
I thought that OGR does this for all supported layers. What it does
for ArcInfo coverage? But as I mentioned above, for GRASS, SFS polygon
is the problem not raw data.
The best for GRASS would be if OGR could optionaly offer data in both
SFS and topological form, if available (Tiger, Coverage).
Otherwise OGR builds polygons from topology, v.in.ogr imports polygons
and v.clean must be used to split polygons and remove duplicates.
Radim
It is not very practical to use 8 commands instead of 1. As it is now, it cannot be too much simplified and the solution within GRASS
would be probably v.in.tiger based on OGR, but that is what we wanted to avoid and to have only one import module, see below.
I thought that OGR does this for all supported layers. What it does for ArcInfo coverage? But as I mentioned above, for GRASS, SFS polygon
is the problem not raw data. The best for GRASS would be if OGR could optionaly offer data in both
Radim,
I would agree that it is desirable for OGR to offer access to topological
vector datasets in some means where v.in.ogr could take care of the eight
steps you delimited automatically. To do this, as I see it, I would need
to modify OGR to keep track of the relationship between polygon records, and
their corresponding arcs in a standard means. In other systems I have kept
metadata on polygon layers indicating the corresponding arc layer, and marking
which arc attributes were the right/left polygon indicator. This would
in theory be enough information for v.in.ogr to build a topological dataset
on import, right?
I notice you utilized the PIP (point-in-polygon) layer. Is this important?
Best regards,
