Hello Frank, I got the zip file from the srtm and…
GRASS:~/grass/srtm/prueba > ls
06594167.zip
GRASS:~/grass/srtm/prueba > unzip 06594167.zip
Archive: 06594167.zip
creating: 06594167/06594167/
inflating: 06594167/06594167.AUX
creating: 06594167/INFO/
inflating: 06594167/METADA~1.HTM
extracting: 06594167/06594167/DBLBND.ADF
inflating: 06594167/06594167/HDR.ADF
inflating: 06594167/06594167/PRJ.ADF
inflating: 06594167/06594167/STA.ADF
inflating: 06594167/06594167/W001001.ADF
inflating: 06594167/06594167/W001001X.ADF
inflating: 06594167/INFO/ARC.DIR
inflating: 06594167/INFO/ARC0000.DAT
inflating: 06594167/INFO/ARC0000.NIT
inflating: 06594167/INFO/ARC0001.DAT
inflating: 06594167/INFO/ARC0001.NIT
GRASS:~/grass/srtm/prueba/06594167 > gdalinfo 06594167.AUX
Driver: HFA/Erdas Imagine Images (.img)
Size is 405, 465
Coordinate System is `’
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 465.000)
Upper Right ( 405.000, 0.000)
Lower Right ( 405.000, 465.000)
Center ( 202.500, 232.500)
Band 1 Block=405x4 Type=Float32, ColorInterp=Undefined
If a use gdalinfo with any other file, I got the next message:
GRASS:~/grass/srtm/prueba/06594167/06594167 > gdalinfo W001001.ADF
ERROR 4: `W001001.ADF’ not recognised as a supported file format.
GDALOpen failed - 4
so I did,
GRASS:~/grass/srtm/prueba/06594167 > r.in.gdal input=06594167.AUX output=dem
PROJ_INFO file not found for location dem
PROJ_UNITS file not found for location dem
ERROR 1: Can’t find RasterDMS field in Eimg_Layer with block list.
[A lot of times]
100%
CREATING SUPPORT FILES FOR dem
I don´t know if I´m doing the things in the correct way,
Thank you
felipe
