the import of DXF is not a problem and we have been doing it.
It is a WISH THAT
- If the TEXT inside a polygon automatically becomes it’s attribute after import into GRASS!!\
It would save a lot of time.
May be the developers of GRASS may kindly consider this aspect… in the next GRASS CVS release…
Ravi
Markus Neteler neteler@itc.it wrote:
I have tested the map with GRASS 6 (not knowing the
coordinate system):v.in.dwg Geology.dxf out=geologydxf
MTEXT entity not supported
3555 elements processed
Building topology …
3538 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 2581
Number of primiti! ves: 3538
Number of points : 16
Number of lines : 3522
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0The database contains now:
v.db.select geologydxf
cat|entity_nam|color|weight|layer|block|txt
1|POINT|256|-1|TICS||
2|POINT|256|-1|TICS||
3|POINT|256|-1|TICS||
4|POINT|256|-1|TICS||
5|POINT|256|-1|TICS||
6|POINT|256|-1|TICS||
7|POINT|256|-1|TICS||
8|POINT|256|-1|TICS||
9|POINT|256|-1|TICS||
10|POINT|256|-1|TICS||
11|POINT|256|-1|TICS||
12|POINT|256|-1|TICS||
13|POINT|256|-1|TICS||
14|POINT|256|-1|TICS||
15|POINT|256|-1|TICS||
16|POINT|256|-1|TICS||
17|LINE|256|-1|GELI236||
18|LINE|256|-1|GELI236||
19|LINE|256|-1|GELI236||
20|LINE|256|-1|GELI236||
21|LINE|256|-1|GELI236||
22|LINE|256|-1|GELI236||
23|LINE|256|-1|GELI236||
24|LINE|256|-1|GELI236||
3536|LINE|256|-1|GELI236||
3537|LINE|256|-1|GELI236||
3538|LINE|256|-1|GELI236||I don’t know if this is what you expected but to some extent
you can import the DXF file.Regards
Markus Neteler
On Thu, Jun 09, 2005 at 05:57:04AM -0700, RAVI KUMAR wrote! :
Iam attaching a small 1:50000 scale geological map,
which is scanned and vectorised manually by a
draftsman.When this is imported into ARC-INFO, the inscribed
text in each Geological polygon becomes its attribute.This is a very quick method,
- where all the digitization is done by the not so
computer savvy draftsmen- Then the Geologist imports it into ARC-INFO to
convert into a digital data with a vital link
attribute.- The geologist then attaches an external database
table using this link attribute.If U can make such a thing possible in grass, then we
can use OGLed Qcad on linux, for the draftsmen and
GRASS for the Geologists.
Ravi— Markus Neteler
Discover Yahoo!
Find restaurants, movies, travel & more fun for the weekend. Check it out!
