[GRASSLIST:7152] v.in.ascii and 6.* tables
I want to import an ASCII x,y,value into a Grass 6.* vector map and use r.surf.idw to interpolate a surface. I can’t seem to get the syntax right.
A line of the ASCII file:
89.1 23.5 1202.1232
that represent x y value.
I use:
cat file1.tab | v.in.ascii out=map1 x=1 y=2 cat=3 fs=\ columns=‘x double, y double, cat double’
v.in.ascii reports 12838 point imported, and I can display them ok.
I then try:
v.surf.idw input=map1 output=map1r col=cat
v.surf.idw complains: ERROR: Cannot open old vector map1@jwortel on level 2.
I suppose the col option should point to a field in the attribute table of map map1, but I don’t see any associated mpa1.dbf file.
any help is greatly appreciated.
Jeroen.
use r.surf.idw to interpolate a surface. I can't seem to get the
syntax right. A line of the ASCII file:
89.1 23.5 1202.1232
I use:
cat file1.tab | v.in.ascii out=map1 x=1 y=2 cat=3 fs=\ columns='x
double, y double, cat double'
fs=\ ?
category must be an integer.
Ok. Try a query with d.what.vect to be sure.
I then try:
level 2. I suppose the col option should point to a field in the
attribute table of map map1, but I don't see any associated mpa1.dbf
file.
maybe "old vector" is an important clue?
What does v.info say?
Hamish
Hi Hamish,
I found out the correct syntax after some extra experimenting.
I was not sure how to cope with the category value, but saw that I need auto-assignment of actegory number with cat=0. I then specify the value that I wan't to interpolate as a double.
in the file:
         89.1 23.5 1202.1232
syntax:
         cat file1.tab | v.in.ascii out=map1 x=1 y=2 cat=0 fs=space columns='x double, y double, value double'
I then use the attribute 'value' to interpolate.
I was somewhat confused that 'x' and 'y' need to be specified again in the columns option, but 'cat' not, although it is still a field in the resulting dbf. But then it isn't in the inputfile, isn't it.
You were right that fs=\ is wrong, it should of course be fs=space. I was confused with scripting syntaxes.
Thanks for your help,
-Jeroen.
fs=\ ?
> I then try:
> file.
Hamish
No virus found in this incoming message.
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.7.3/15 - Release Date: 14-6-2005
RC(0.3)1r2m B-- C-- D++ F N- S? O! OCGP a29
No virus found in this outgoing message.
