[GRASSLIST:724] problems with MASK
Hi
I´ve been trying to create a mask in order to visualize the area where my
data were collected.
I´ve made a mask that represents the boundary of this area using r.digit.
The mask is a raster map with value 1 (inside the area) and NULL (outside
the area).
With mapcalculator I´ve made the product of the mask and the interpolated
surface of my datafile. Also I used this mask as the raster file mask to
generate the grid 3d file of my data.
It works when I visualize the surfaces in grass but it doesn´t work
properly when I try to visualize the volume (isosurfaces) with nviz - the
isosurfaces don´t cover the hole area just a part of it.
I`ve made a lot of tries but the results are almost the same.
Is there another way to create this mask?
I would appreciate if someone could help me.
Thanks a lot
Hello Andrea,
On Mon, 17 Apr 2006 02:03:40 -0300 (BRST) andrea.iescheck@ufpr.br wrote:
Hi
where my data were collected.
r.digit. The mask is a raster map with value 1 (inside the area) and
NULL (outside the area).
interpolated surface of my datafile. Also I used this mask as the
raster file mask to generate the grid 3d file of my data.
the isosurfaces don´t cover the hole area just a part of it.
I am not sure what the correct name for 3d-mask is, but I *think* it is
different than MASK. Perhaps someone with more experience can elaborate
on this a bit more.
Best
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
