Dear GRASSusers,
does it exist the db.droptable command?
It is described in the GRASS GIS Reference Manual and in many tutorials, but
it seems not to exist in my GRASS version (6.1.cvs).
Thanks to everybody.
A. Clerici
Parma University
Dear GRASSusers,
A. Clerici
Parma University
On Tue, June 21, 2005 18:40, Aldo Clerici said:
Dear GRASSusers,
Currently it does not exist. The recommended way of dropping a table is:
echo "DROP TABLE fmacopy" | db.execute
However, it wouldn't be too difficult to create a db.droptable if there is
real demand.
Moritz
I have been learning the GRASS SQL commands and don't fully understand
why there are individual commands for some SQL statements and not
others (for example why not just have db.execute?). In fact, I have
found some SELECT statements don't work in db.execute but do work in
db.select. This seems a bit confusing to me.
David
> Dear GRASSusers,
> it seems not to exist in my GRASS version (6.1.cvs).Currently it does not exist. The recommended way of dropping a table is:
real demand.Moritz
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
I think that's because SELECT is for access the date while EXECUTE is for manage the data.
So if you want to delete, update or insert some data db.execute is the right command,
while for extract and query the data db.select is the right one.
Maxi
db.select. This seems a bit confusing to me.David
Dear GRASSusers,
real demand.Moritz
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 18
Fax +41 (0)58 666 62 09
right command,
+ db.execute is for the "power" user, i.e. the one who is willing to learn
some SQL. The other commands are just frontends to db.execute to make life
easier for those that need a little help.
Moritz
Dear GRASSusers,
but
real demand.Moritz
