hi,Moritz
hi All
for prepairing slop map and aspect map:is there any better way exept :
r.slope.aspect el=…format=percent…
then: r.report …is completly wrong…like 8905percent ,8920 percent…and…
if somebody knows please help me
Ramin
: r.slope.aspect el=.....format=percent...
then: r.report ...is completly wrong....like 8905percent ,8920
percent......and... if somebody knows please help me
Does your elevation map have any really steep terrain (sheer cliffs)?
How does the region resolution match up with the elevation map's
resolution?
Is the elevation map integer based or floating point? (r.info Data Type)
Are you sure your elevation map is ok (no interspersed 0s)?
format=percent returns tan(degrees) and tan(90) is infinite..
8920% is fairly strange though. That's a 89.993 deg slope.
The most I'm seeing in my submarine canyons is about 388%
The module works fine for me using the following convention:
[GRASS 5.0.2]
