[GRASSLIST:7334] grass has been running for three days
hello
grass has been running for three days to create watershed related maps.
At this moment, it has been in this stage for a long time (almost one day):
Running: /usr/lib/grass/etc/water/ram el="el_5" t=100 se="str_5" ha="hbas20_50"
SECTION 1a (of 5): Initiating Memory.
SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
SECTION 2: A * Search. Percent complete:
SECTION 3: Accumulating Surface Flow. Percent complete:
SECTION 4: Watershed determination.
SECTION 5: Closing Maps.
I am not sure if grass will be able to complete it's job ?
or
is it a good idea to cancel the job and start again with smaller region?
what do you suggest ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Congrats!
This is well known bug in GRASS by some users (i.e. me). GRASS will
never finish this watershed creation. You can safely ctrl-c it and
forget about it.
More info: http://www.intevation.de/rt/webrt?serial_num=3112&display=History
wbr,
Maris.
On 6/28/05, orkun <temiz@deprem.gov.tr> wrote:
hello
ha="hbas20_50"
or
regards
Ahmet Temiz
prcessing very large maps is quite slow with r.whatershed (I guess you are using this command!).
I suggest to give a try to r.terraflow, it has been created for large raster file processing....
Hope this help.
Maxi
orkun wrote:
hello
or
regards
Ahmet Temiz
(attachments)
massimiliano.cannata.31179DEFANGED-vcf (346 Bytes)
Hope this help.
Maxi
orkun wrote:
hello
or
regards
Ahmet Temiz
thank you
as far as I see r.terraflow does not produce half basin.
I need a module that creates half basin other than r.watershed.
regards
>> maps.
>> one day):
>> ha="hbas20_50"
>> or is it a good idea to cancel the job and start again with
>> smaller region?
Looks like the while loop in raster/r.watershed/ram/close_maps2.c
line 38 is never satisfied.
Maybe same endless call to close_array_seg() is what causes bug #3112?
Things often report 98% when actually done as G_percent() is often
called in the wrong place or doesn't get called after exit. (e.g. watch
r.terrflow run) So it is likely it finished & then got stuck on the
cleanup step.
-- how big is the test region?
-- r.info: CELL map, DCELL map?
    (idea- try a CELL version [r.mapcalc 'newmap=int(oldmap)'])
that's about as deep as I can look into it right now.
Hamish
