[GRASSLIST:7387] 3d point vectors in nviz
Has anyone successfully managed to get a 3D points cloud
to display correctly in nviz?
I checked 3D region settings and the structure of the
vector file itself. The data and settings seem fine.
I can display the zcoords with d.vect and it looks
ok.
However, when I load the map into nviz, I only get
to see the top points of the vector map (i.e. I get
to see as much as the top-down view by d.vect),
the remaining points do not get displayed.
I would very much appreciate any help!
Benjamin
ok.
Did you activate "3D Points" in the Vector points menu?
