[GRASSLIST:7388] grass_I error
in the ps.map dir when making binaries, i get this error:
/usr/bin/ld: cannot find -lgrass_I
collect2: ld returned 1 exit status
make: *** [/drive/rpms/grass-6.0.0/dist.i686-pc-linux-gnu/bin/ps.map] Error 1
i recently upgraded to FC4 and cant seem to get grass to work on
it.... any suggestions? =D
need fftw 2.1.5, tcl/tk 8.3, gdal 2.6.x, latest X11 libs. Rebuild all of
those, then try rebuilding grass.
Error 1
Thomas Colson
Center For Earth Observation
North Carolina State University
Raleigh, NC
(919)515 3434
(919)673 8023
tom_colson@ncsu.edu
welll i have fftw 2.15, tcl/tk 8.4, gdal 2.6, and i presume i have
the latest X11 libs because i just upgraded to FC4...
any other suggestions?
> Error 1
Thomas Colson
Raleigh, NC
(919)515 3434
(919)673 8023
tom_colson@ncsu.edu
go back to tcl/tk 8.3 there is a requirement that nviz will not work with
8.4, but I have found (after days of builds, posts, and throwing chairs)
that nothing on FC4 will work with tcl/tk 8.4
the dependencies are very specific for grass6 and it will generally not
work correctly if you upgrade to the next version of even one of
them...it's best to stick with the versions listed in the requirements.
compile each of the requirements and scan the config logs for any errors
before compiling grass. Most of them include test apps (fftw had many
tests) run those to make sure all installed correctly.
Are you aware of the ldconfig trick? Update your path(s) and then run
ldconf...sometimes that helps grass compile correctly.
I went thru this pain with FC4 last week. Good luck.
> Error 1
Thomas Colson
Raleigh, NC
(919)515 3434
(919)673 8023
tom_colson@ncsu.edu
Thomas Colson
Raleigh, NC
(919)515 3434
(919)673 8023
tom_colson@ncsu.edu
GRASS works with tcl/tk 8.4 on various platforms/distros
(except for Debian).
>> > Error 1
please try this:
cd grass-6.0.0/lib/imagery/
make
Which error do you get?
And: do you use gcc4 (run gcc -v)? If so, you need to update
the GRASS source code as related issues have been fixed in
GRASS 6.1-CVS. In this case download either from CVS directly
or get a recent 6.1-CVS snapshot.
please try this:
make
make[1]: *** [/drive/rpms/grass-6.0.0/dist.i686-pc-linux-gnu/bin/i.zc] Error 1
make[1]: Leaving directory `/drive/rpms/grass-6.0.0/imagery/i.zc'
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--enable-checking=release --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-libgcj-multifile
--enable-languages=c,c++,objc,java,f95,ada --enable-java-awt=gtk
--with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
--host=i386-redhat-linux
Thread model: posix
gcc version 4.0.0 20050519 (Red Hat 4.0.0-8)
GRASS 6.0.0 is not compatible with gcc 4.0. Please try the weekly
CVS snapshot of the (future) 6.0.1 bugfix version of GRASS:
http://grass.ibiblio.org/grass60/source/snapshot/
Do let us know how you get on -- we need to know that 6.0.1 supports
gcc 4.0 before it is released.
Hamish
