Hi Guys,
How do i get the minimum bounding rectangle coordinates of each feature within grass? I need to get the UL, UR, LL and LR X and Y coordinates of each feature within a feature class and be able to summarize based on each of these x and y coordinates. So it will be like how many times same ULX is repeated, how many times same ULY is repeated etc.
Any help will be appreciated.
Thanks
On Tuesday 18 April 2006 06:26 am, Sudipta Sarkar wrote:
Hi Guys,
repeated, how many times same ULY is repeated etc. Any help will be
appreciated.
Thanks
interesting question.
a simple way to do this would be with a for() loop in bash, assumming that
each of your features has topology and a CAT value.
make a list of cat values for a given vector:
#complicated vector with overlapping polys, your vector might be simpler
cats=`v.category geo option=print | sort -g | grep -v "/" | uniq`
#loop through these values
for x in $cats
do #extract each feature by cat value
v.extract in=geo list=$x out=geo_$x #zoom to the region bounding this feature and save the output for processing
g.region vect=geo_$x > region_geo_$x.txt #cleanup g.remove vect=geo_$x
#rinse and repeat
done
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
