[GRASSLIST:7490] Newbie having trouble starting GRASS...
I'm having some trouble getting GRASS fired up. I am new to Linux and GRASS, so I appreciate your patience with my efforts to get GRASS running successfully.
I'm running Debian Sarge, and I've installed GRASS 6.0.0.
I followed the direction in the GRASS tutorials, and set up the following folder to hold my GRASS Databases/Data:
/home/linuxuser/GRASS/GRASSDATA
When I start GRASS, I enter the following information in the "Database:" text box of the dialog:
I then click the "Create Location From ESPG", and enter the appropriate ESPG code.
GRASS then automatically shutsdown.
When I restart GRASS, I select the following information in the dialog:
Map Set: PERMANENT
I then click the "Enter GRASS" button.
When I do so the splash screen displays, and after waiting a few seconds I see "done" in the top right corner of the splash screen. However, the splash screen disappears and nothing else happens. Alt-Tab does not bring up any minimized or hidden windows.
What am I doing wrong?
Am I supposed to see something after the splash screen displays.
Landon
Check to insure that your video system is working, particularly tcl/tk and
X11 and/or Xorg. Just because you can see a mouse pointer doesn't mean it's
working. If you're using tcl/tk 8.4, downgrade to 8.3.
Thomas Colson
North Carolina State University
Department of Forestry and Environmental Resources
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
www4.ncsu.edu/~tpcolson
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of Landon Blake
Sent: Thursday, July 07, 2005 1:21 PM
To: GRASS mailing list
Subject: [GRASSLIST:7490] Newbie having trouble starting GRASS...
successfully.
code.
Map Set: PERMANENT
Landon
Hi All,
Our sysadmin has recently installed GRASS 6.0.0
on a Linux system ( with tcl8.4 ). After hitting
RETURN to continue, the Window apppears using
what appears to be a Greek character set.
Any ideas on how to fix this ?
Do I need to ask the sysadmin if we can go back to tcl 8.3 ?
Jean
more FYI than anything....
i had a similar issue/question with tcl8.4. Markus said it was fine
with most linux distributions. mine works great on fedora core 4.
On 7/7/05, Jean Roth <jroth@nber.org> wrote:
Hi All,
Jean
(from the debian package I assume)
Lots of people are using this setup (including me) without problems.
dialog:
Map Set: PERMANENT
(best to make a working mapset rather than using PERMANENT)
Hard to say.
Start grass from a terminal window (just type grass at the prompt) and
see what happens that way. If it still fails try starting in text mode
by typing 'grass -text' at the terminal prompt. If GRASS starts, type
"d.m &" at the prompt to start up the GUI. Starting up this way should
give you some clues as to what went wrong. Restart GRASS with
'grass -gui' to get it to start in GUI mode again. If it still doesn't
work, file a bug against the Debian package.
Alt-tab won't do anything unless you've gone into the key bindings
config and set up Gnome/KDE/whatever to respect that.
The GIS manager window should show up as well as a terminal window.
Folks: the tcl/tk 8.3 vs 8.4 issue only has to do with NVIZ, and then
mostly only seen on Debian. The d.m GIS manager stuff should be fine.
NVIZ will crash with a segfault on startup if *built* with the Debian
tcl/tk 8.4 development packages. You *can* have TclTk 8.4 installed and
actually *run* GRASS, d.m, and even NVIZ using the Tk 8.4 version of
'wish' without any problems. The restriction is just that it has to be
compiled by the Debian packager using the 8.3 development packages.
(I think it's a threading issue.)
Hamish
