[GRASSLIST:7564] Synergy between Grass/Python/GMT
I've been working on a script to convert GRASS rasters directly into
GMT plots in a single command. So far it converts the raster to GMT
format, copies over the colormap and builds a simple graticule and
scale bar. Works well.
In the process of building this script, however, I discovered there is
some great synergy possible between IPython (the interactive python
shell) and GRASS. Here is how it works:
1) Launch ipython from within your grass shell
2) import a simple class designed to work with rasters
3) BINGO! you've got full control of command line grass + full
interactive Python abilities.
The class I wrote for grass rasters contains a bunch of instance
variables that hold basic info about the raster (resolution, bounding
box, etc.) and some methods to ease interaction with Python, like a
get_value(X, Y) method.
There are some really powerful things you can do with this that cannot
be done with any other GIS. Very cool!
David
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
Hello David,
On Fri, 15 Jul 2005 16:27:18 -0700 David Finlayson
Would you like to share the python class which you wrote for
raster-maps?
It would be nice having the class in CVS to make it possible for others
too?
Thanks for your comment
  Stephan
       ::ACHTUNG:: Neue Adresse und Telefonnummer ::ACHTUNG::
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
I'd be happy to share it, but frankly it's pretty crude. I'd be
embarrassed to foist this off as a good example of either Grass or
Python (though maybe it is a good example of how flexible this
combination is, even for light-weight programmers). The class simply
wraps an interface around a few standard GRASS commands and captures
the results (r.region for example). My dream is to write a real Python
interface to the Grass programming interface, but that project is on
hold until I finish my PhD.
Is there a good place on the wiki for sharing scripts? When I get this
GMT thing polished up I think it will be quite useful for folks who
use GMT.
David
On 7/15/05, Stephan Holl <holl@gdf-hannover.de> wrote:
Hello David,
raster-maps?
too?
        Stephan
David Finlayson
Box 357940
USA
David,
I am extremely interested in any possible ways to streamline the GRASS-GMT workflow.
I have started documenting a BASH shell version of the process, but a python interface might be able to provide a tremendous amount of flexibility compared to BASH.
The website where this is documented is currently down (power outage while I was out in the field...), but I will try and have it back up in a couple hours. Please let me know about any future plans with this--
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
use GMT.
David
Hello David,
raster-maps?
too?
        Stephan
David Finlayson
Box 357940
USA
I have posted my GRASS -> GMT script on my web site (r.out.gmt.py):
http://students.washington.edu/dfinlays/scripts/
If anyone finds this useful, please send me suggestions. I will keep
working on it until it isn't such a hack.
Currently, it converts a raster, its colormap and optionally an
intensity raster (such as shaded relief) to GMT format. It then builds
a skeleton GMT plotting file that includes the raster (optionally
shaded with the intensity grid), a graticule and map decorations with
all of the tedious scale calculations already performed.
You need to edit the results to get it to look right, but the time
savings (for me) is probably close to an hour a plot over doing the
same steps manually.
David
On 7/16/05, Dylan Beaudette <dylan@iici.no-ip.org> wrote:
David,
GRASS-GMT workflow.
Dylan Beaudette
530.754.7341
> use GMT.
> David
>> Hello David,
>>> is
>> raster-maps?
>> others
>> too?
>> Stephan
> David Finlayson
> Box 357940
> USA
David Finlayson
Box 357940
USA
David,
As I alluded to last message, here is the link to the BASH GRASS--GMT framework that I have put together to help with my map making:
http://169.237.35.250/~dylan/grass_user_group/
with a sample map :
http://169.237.35.250/~dylan/grass_user_group/map1.html
...however I am looking forward to checking out your python code... BASH is a little crufty..
Dylan Beaudette
530.754.7341
David
David,
GRASS-GMT workflow.
Dylan Beaudette
530.754.7341
use GMT.
David
Hello David,
is
raster-maps?
others
too?
        Stephan
David Finlayson
Box 357940
USA
David Finlayson
Box 357940
USA
Nice web site. You've obviously thought about this for a while now.
Maybe we can work on this together to get it polished up for general
consumption?
David
On 7/17/05, Dylan Beaudette <dylan@iici.no-ip.org> wrote:
David,
with a sample map :
Dylan Beaudette
530.754.7341
> David
>> David,
>> GRASS-GMT workflow.
>> in
>> Cheers,
>> Dylan Beaudette
>> 530.754.7341
>>> Python
>>> this
>>> use GMT.
>>> David
>>>> Hello David,
>>>>> into
>>>>> is
>>>>> bounding
>>>> raster-maps?
>>>> others
>>>> too?
>>>> Stephan
>>>> sensing
>>>> Hannover
>>> David Finlayson
>>> Box 357940
>>> USA
> David Finlayson
> Box 357940
> USA
David Finlayson
Box 357940
USA
Hello David, Dylan
On Sun, 17 Jul 2005 14:17:10 -0700 David Finlayson
Cool! Thanks for sharing it.
If you think it has a useful state, I would like to see it in the
WIKI-Add-on-section at
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
best
  Stephan
use GMT.
The AddOns page:
Please add copyright and license information so that others may know how
they can use your script. If your website will one day disappear, it
would be nice to upload the script to the Wiki at some point ("Attach
file") instead of just adding a link. We can't rely on the Wayback
Machine's ablility to survive future lawsuits.
Hamish
ps - Stephan: I again get a read error when I try to edit that wiki page.
I am wondering if it makes more sense to break up the program into
separate scripts?
1) Convert the color table from grass to gmt (g.out.colortable format=gmt)
2) Converting the raster (r.out.gmt)
3) Suggest output for -R and -J (maybe keep this in GMT land)
I just don't like the spaghetti code I was writing.
David
On 7/18/05, Dylan Beaudette <debeaudette@ucdavis.edu> wrote:
David,
Thanks for the reply. The lack of good hard copy output from GRASS has
driven me to do some hackish things in order to get GMT to produce my
maps.... I would be more than happy to collaborate on getting a working
GRASS-GMT framework (python seems like the best glue language as you
have demonstrated!) . I am excited about trying your script, as it
solves the color pallette problem that I had been facing for a while. I
am also working on a v.out.gmt script to convert GRASS vector data and
attributes into GMT format. Currently the only way to get GRASS vector
data into GMT is to convert to shapefile, and then convert the geometry
to GMT format.
Cheers!
Dylan Beaudette
530.754.7341
> consumption?
> David
>> David,
>> with a sample map :
>> Dylan Beaudette
>> 530.754.7341
>>> builds
>>> David
>>>> David,
>>>> GRASS-GMT workflow.
>>>> a
>>>> in
>>>> this--
>>>> Cheers,
>>>> Dylan Beaudette
>>>> 530.754.7341
>>>>> simply
>>>>> captures
>>>>> Python
>>>>> on
>>>>> this
>>>>> use GMT.
>>>>> David
>>>>>> Hello David,
>>>>>>> into
>>>>>>> GMT
>>>>>>> and
>>>>>>> there
>>>>>>> is
>>>>>>> python
>>>>>>> bounding
>>>>>>> like a
>>>>>> raster-maps?
>>>>>> others
>>>>>> too?
>>>>>> Stephan
>>>>>> sensing
>>>>>> Hannover
>>>>> David Finlayson
>>>>> Box 357940
>>>>> USA
>>> David Finlayson
>>> Box 357940
>>> USA
> David Finlayson
> Box 357940
> USA
David Finlayson
Box 357940
USA
separate scripts?
(Background)
I have a written a shell script which I use to generate a GMT version of a
QGIS project. I can create a view of various PostGIS layers in QGIS, set
line/polygon/point colors and polygon fills. The script parses a QGIS
project file, identifies the map extent & PostGIS layers, extracts the
relevant features, converts to GMT vector format & writes a script to plot
the files using the QGIS region & colors.... Pretty basic, lots of things
it doesn't do, but the resulting GMT files & script make generating a GMT
plot from an on screen view very easy. (The Postgis to GMT conversion is
via a perl script someone else (with much better programming skills)
wrote)
(comments)
I think a modular, generalised approach will offer more to users than a
monolithic approach, so the idea of several specific functions to export
raster & vector data for GMT is great.
Is there any way such capability could be added to gdal/ogr instead of
being GRASS specific? I know GDAL has some GMT support now, so
things like geotiff <-> gridfile can be done, but color pallete
support within GDAL would be tidier. Also adding GMT vector format
to ogr would be a much more versatile approach than a GRASS specific
function, and would also work with GRASS as well.
I'm more a fan of functionality than elegance, so I'll happily leech off
any contributions in this area :slight_smile:
> David,
> to GMT format.
Are you interested in a copy of the PostGIS -> GMT perl script I mentioned
above? It's small enough to post, but isn't strictly a GRASS function. I'm
also interested in how you turn shapefiles into GMT (and vice versa). My C
coding isn't up to much more than spelling the name of the language, so I
haven't done much with shapelib, or Ben's gmt version that I never got
working properly... (but I guess these are more GMT list questions than
GRASS...)
Anyway, I'm very interested in these capabilities, and also the ability to
invoke GMT to plot data from R. I believe the PostGIS/QGIS/GRASS/GMT/R
suite could be the most powerful analytical GIS suite available, so any
work to enhance the interoperability of these packages is fantastic!
  Brent Wood
