using r.buffer how might I perform an interior buffer. That is take the outside of a raster clump (from r.clump) and make concentric internal buffers at 100, 200, 300 meters etc?.
The use is determining a wheighted score for habitat sensitive to edge disturbances.... check out http://www.udel.edu/johnmack/frec682/682proj2.html right at the end, fourth paragraph from the bootom.
this would be a benifical discovery. I thought of using a centroid and buffering out from that, but that is not accurate for the EDGE distaurbance
I tried using -100,-200 (no quotes) etc and also '-100' (single quote) and "-100" (double quote). No mention in the MAN pages of 6.0 or past versions.
Crucials:
Cygwin GRASS 6.1 CVS through Cygwin install
windows XP
don't imagine it is something on compiling as its a process that should be inherent somewhere.
Thanks
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis@watersheds.ca |
