Hello,
when using r.statistics with method "variance" I receive NAN as output values,
however if I use "average" or "stddev" the ouput looks reasonable.
I tried it with GRASS 6.1-cvs a few weeks ago and GRASS 6.0 from the debian
repository but both produced the same result.
Any idea what the problem might be?
r.statistics base=loc_july05 cover=topo_resample method=variance
output=test.var
thanks in advance, Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
The m_var() function fails to initialise the local variable "s".
Fixed in CVS, or apply the attached patch.
(attachments)
r.statistics.diff (283 Bytes)
On Fri, Jul 22, 2005 at 06:12:15AM +0100, Glynn Clements wrote:
Content-Description: message body and .signature
I have also fixed it in 6.0-CVS (for 6.0.1).
thanks!
regards, Martin
> values, however if I use "average" or "stddev" the ouput looks
> reasonable.
> debian repository but both produced the same result.
Martin Wegmann
Dept.of Geography
Dept. of Animal Ecology and Tropical Biology
Am Hubland
97074 Würzburg
