Help!
I'm trying to load a USGS STDS DEM model of a single quadrangle into Grass 6.0.
The system agreed to import the data and produced the messages below. It appears to
be stuck in a loop - it has been running for 12 hours, with a process named set_data
consuming nearly 100% of the cpu cycles. This cannot be normal, or no one would ever
get anything done.
The only hint of an error in the messages is the note that no transformation parameters
were specified. When I was setting up the region, I did specify that the system should use the
default, but that seems to be interpreted as not specifying anything at all. And the system then
notes that it is using the nad27 values as a default.
So, what am I doing wrong? I am still on the vertical portion of the learning curve, and any
help will be most appreciated.
tia,
david
OUTPUT:
r.in.gdal 'input=/home/david/gis/DEMs/California/Lake County/Middletown/8976CATD.DDF' output=DEM 'title=Digital Elevation Model'
A datum name nad27 (North_American_Datum_1927) was specified without transformation parameters.
Non-interactive mode: the GRASS default for nad27 is towgs84=-22.000,157.000,176.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
CREATING SUPPORT FILES FOR DEM
The grass message above the line has not changed in ~12 hours
System: Fedora core 3, Grass 6.0, 2.8 MHz Pentium 4, 512 MB (Dell 4700)
top - 08:52:46 up 1 day, 2:00, 3 users, load average: 2.36, 2.32, 2.38
Tasks: 95 total, 2 running, 93 sleeping, 0 stopped, 0 zombie
Cpu(s): 69.4% us, 30.6% sy, 0.0% ni, 0.0% id, 0.0% wa, 0.0% hi, 0.0% si
Mem: 506232k total, 497592k used, 8640k free, 76244k buffers
Swap: 1020088k total, 208k used, 1019880k free, 100588k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6887 david 25 0 2708 1144 816 R 98.9 0.2 782:19.00 set_data
6890 david 15 0 38012 13m 8440 S 0.7 2.7 0:25.51 gnome-terminal
4878 david 25 10 34120 19m 10m S 0.3 4.0 0:08.93 rhn-applet-gui
...snip...
