When importing ESRI shape (shp) files are there primary steps you should take before even thinking of importing them. I feel as though things just are not working, what am I missing? What doc or man page did I miss?
I have been battling shape files all week. All of the bellow do not occur each time, but these are challenges I have been facing.
* I have to use OGR at the command line to change projections (GRASSLIST#7683)
* similar projections don't line up in GRASS like they did in ARCVIEW
* I loose chunks of data (missing polygons) (GRASSLIST#7685)
* SHX files become "currupt"
* PROJ files when present are not read corectly or at all
* Area information is lost and random warnings appear
Is there a script you can run on a SHP file to see if anything BAD will happen to it before trying to bring it into GRASS and messing things up?
P.S Thanks for your ongoing patience and expertise.
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis@watersheds.ca |
