[GRASSLIST:7699] r.volume (what would be the equivalent)
hey folks,
Working off an old tutorial [http://www.udel.edu/johnmack/frec682/682proj2.html\] r.volume was required for a process.
quote:
Now run /r.volume /on this buffer-weighted habitat score map to obtain the sum and average of each clump's cell habitat scores Use /awk/ to create reclass rules files, then use /r.reclass/ to map the largest clumps by sum and average habitat scores. Which clump has the highest weighted total habitat score? Which has the highest weighted average habitat score?
I thought that running r.stats might work, but don't understand how to get stats per clump. Each clump has a wheighted score depending on its distance from the edge. I would like to take the weighted score of each clump and perform the stats on that, not just the invidual interior buffers.
cheers
|Dave Sampson: Geographic Information System (GIS) Technician |
|Centre for Sustainable Watersheds |
|Cooperative Approaches to Protect Canada's Water Resources |
|14 Water St, P.O Box 280. Portland Ontario, Canada. K0G 1V0 |
|Lat: 44.700 Long: -76.19 |
|www.watersheds.ca gis@watersheds.ca |
