Problem with invisible vectors is solved. I've also been getting a problem
Error: WARNING: Invalid timestamp file for raster map map12_surf in mapset PERMANENT.
In another project, I removed the time stamp file. This is a map created under GRASS 5.0.x from vector elevations. They have been working fine until this point. Is removing the time stamp the way to go on all of them?
mapset PERMANENT.
go on all of them?
