[GRASSLIST:7775] "densifying" or adding vertices to breaklines
We're looking to add points from breaklines into our DEM point maps, so we can do terrain analysis. Is there a similar concept in GRASS for doing this? Perhaps this is the way to do it, let me know if you have any ideas.
Tyler
Hi Tyler,
You can use v.to.points to create points along your contour lines. After, you should use v.patch to combine your points layer.
Sadly, I can't explain you how to create your attribute table when you do your v.patch command. I ask a question about that this morning but I don't get an answer by now.
There is also some parameters that can be pass to v.surf.rst to deal with this.
Hope this help,
Jean-Denis
Tyler
Merci JD, I now understand better what you meant. It sounds like we are after the same thing - now we just need some help! :slight_smile:
Tyler
Jean-Denis Giguere wrote:
Hi Tyler,
Hope this help,
Jean-Denis
Tyler
to join two vector data sets use v.append from wiki. It will join
atribute data tables too. Unfortunatly it is slow on large data sets.
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
Maris.
On 8/4/05, Jean-Denis Giguere <jdenisgiguere@fastmail.fm> wrote:
Hi Tyler,
with this.
Hope this help,
Jean-Denis
> any ideas.
> Tyler
have any ideas.
If I understand correctly (which is always doubtful), try (v.segment or
v.split from grass 6.1-cvs) + v.to.points -v.
Hamish
(sorry for the late reply)
