Hello,
ive got the Problem, that i have to georeference a png-File
automatically. I know the coordinates of 4 points (longitude + latitude
and the coordinates in the image). I want to read them in automatically.
Is this possible?
Greetings
Maik
Hello again,
i think there is no module which can do that. But if i would know where
and how i.vpoints safes its results, it would probably be possible to
hand over the needed parameters to i.rectify. Or to safe the parameter
in a way i.rectify can use them.
Does anybody know how i.vpoints safes its results?
Greeting
Maik Trömel
Von: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] Im
Auftrag von Maik Trömel
Gesendet: Donnerstag, 4. August 2005 12:37
An: GRASSLIST@baylor. edu
Betreff: [GRASSLIST:7788] automatic georeferencing
Hello,
Is this possible?
Greetings
Maik
On Thu, Aug 04, 2005 at 01:36:58PM +0200, Maik Trömel wrote:
Hello,
i’ve got the Problem, that i have to georeference a png-File
Is this possible?
You can either generate the POINTS file of i.points with
a script or alternatively use
# define the four coordinates:
gdal_translate -gcp x1 y1 refx1 refy1 -gcp x2 y2 refx1 refx2 ... image1.tif image1_gcps.tif
gdalwarp image1_gcps.tif image1_geocoded.tif
Please refer to http://www.gdal.org for details (if needed).
