[GRASSLIST:7806] NVIZ problems
Hi all
I have installed Grass 6.0 onto an AMD 64 platform running SUSE 9.2
Pro 64 bit and it works fab, but I cannot seem to get NVIZ to work (a
shame because I would like to do some 3d visualisation projects).
My errors specifically are:
Application initialization failed: Can't find a usable init.tcl in the
following directories:
   /usr/lib/tcl8.4 /usr/local/grass-6.0.0/lib/tcl8.4
/usr/local/lib/tcl8.4 /usr/local/grass-6.0.0/library
/usr/local/library /usr/local/tcl8.4.7/library /usr/tcl8.4.7/library
/usr/lib/tcl8.4
so, I created /usr/lib64/tcl8.4 and set a symlink
ln -s /usr/lib64/tcl8.4/init.tcl /usr/lib/tcl8.4/init.tcl
Alas no go..
Has anyone else had this problem and if so any ideas would be most
gratefully received.. beers to all!
Mark
Mark,
On Sat, Aug 06, 2005 at 10:47:08AM +0100, mark balman wrote:
Hi all
I have access to a 64bit RHEL4 box.
/usr/lib/tcl8.4
Alas no go..
Mine stays here:
/usr/share/tcl8.4/init.tcl
I configured like this:
# with debugging:
export CFLAGS='-g -Wall'
# RHEL 4:
./configure \
  --enable-64bit \
  --with-libs=/usr/lib64 \
  --with-cxx \
  --with-gdal=/usr/local/bin/gdal-config \
  --with-postgres-includes=/usr/include/pgsql --with-postgres-libs=/usr/lib \
  --without-mysql \
  --without-odbc \
  --with-motif \
  --with-motif-includes=/usr/X11R6/include/Xm \
  --with-glw \
  --with-nls \
  --with-fftw \
  --with-freetype --with-freetype-includes=/usr/include/freetype2 \
  --enable-largefile \
  --without-opendwg \
  2>&1 | tee config_log.txt
Note that I had to compile FFTW2 like this:
CFLAGS="-fPIC" ./configure
Hope this helps
