[GRASSLIST:7825] distance between two points
Is there a grass function that will calculate the distance between two points on a vector layer? How about between a point on a vector layer and a cell on a raster layer?
Yes.
- direct distance: v.distance
- along a vector network: v.net.path/d.path
- you may convert the cell center to a vector point (r.to.vect)
- then above functions
To put it simply:
I have a vector layer that contains a point of interest. I'd like to know the distance from that point to every cell in a raster layer that covers the same area. I did look through all the commands I did not find anything that allows one to compare features between vector and raster layers.
On Aug 8, 2005, at 3:56 PM, David Finlayson wrote:
Have you looked through the commands and not found what you need
there? These commands: v.distance, d.geodesic, d.measure, r.buffer,
r.distance all do a variation on the theme.
If these don't work, maybe you can describe what you are trying to
accomplish in more detail.
David
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
