Dear,
a long time ago...(> 10 years) I was an intensive GRASS user.
Unhappily, I have now no access to an unix/linux machine with GRASS.
I want now to convert the two attached GRASS (4.2) packed binary integer raster files to ascii grids. Could somebody help me? Or is there somewhere a tool to do this in windows?
best regards
Okke Batelaan
Dept. of Hydrology and Hydraulic Engineering
Vrije Universiteit Brussel
Pleinlaan 2, 1050 Brussels, Belgium
tel: x-32-2-6293039, fax: x-32-2-6293022
mailto:batelaan@vub.ac.be
http://homepages.vub.ac.be/~batelaan
(attachments)
tracewal (19.9 KB)
tracewal.hd (194 Bytes)
jarcmp1 (165 KB)
jarcmp1.hd (194 Bytes)
I'll email you the converted files.
GRASS can be run on Windows using Cygwin, although it's a bit more
awkward to set up (mostly because you have to get your Cygwin
environment set up right).
Try the grasslivecd working on windows:
https://www.geographie.uni-freiburg.de/~mlechner/xlivegrass/
all module working good and no time consuming in installing...
it could result a bit slow...
so take a look at
http://www.dirap.unipa.it/~scianna/grass_gis_6-0-0.htm
for some tips on how run it in a faster way... (Using GRASS GIS 6.0 under Windows XP)
hope this can help.
Maxi
Dear,
best regards
proj: 0
zone: 0
north: 186250
south: 170250
east: 192000
west: 180000
cols: 240
rows: 320
e-w resol: 50
n-s resol: 50
format: 2
compressed: 1
proj: 0
zone: 0
north: 185590
south: 171640
east: 191550
west: 180900
cols: 355
rows: 465
e-w resol: 30
n-s resol: 30
format: 1
compressed: 1
Massimiliano Cannata
Environmental & Geomatic Engineer
Institute of Earth Scences - SUPSI
Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
Tel: +41 (0)58 / 666 62 18 Fax: +41 (0)58 / 666 62 09
massimiliano.cannata@supsi.ch, www.supsi.ch
