unfortunally any band raster has only null values...
thanks, Michele.
hallo,
try g.list rast
r.composite ...
jachym
On Thu, Aug 11, 2005 at 11:49:44AM +0200, Michele wrote:
> Hi,
> i'm having a problem importing "tiff" file with the related .tfw file using r.in.gdal, both with grass60 and grass54. The import process seems to run, but the resulting map is a null value empty map.
> The same tiff file is correctly imported by the r.in.tiff module in grass54.
> I tried to search some similar issue in the web, but had no results related to my problem...
> Thanks, Michele.
> ____________________________________________________________
> Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
> Abbonati subito su http://www.libero.it
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
what about region?
g.region -dp
g.region rast=rast.red
d.rast rast.red
Jachym
On Thu, Aug 11, 2005 at 12:10:55PM +0200, Michele wrote:
thanks, Michele.
> hallo,
> try g.list rast
> r.composite ...
> jachym
> > Hi,
> > Thanks, Michele.
> Jachym Cepicky
Jachym Cepicky
Jachym Cepicky wrote:
what about region?
g.region -dp
d.rast rast.red
If this works, it probably means that the .tfw file was ignored, in
which case you need to use r.region to correct the map's position.
