[GRASSLIST:7861] Re: r.in.gdal tiff problem
I prepared a new location and it works, the problem was that I was using an old location from a backup and there was somethig wrong with the proj parameters in that old one, sorry :wink:
Thanks!
Jachym Cepicky wrote:
> what about region?
> g.region -dp
> g.region rast=rast.red
> d.rast rast.red
If this works, it probably means that the .tfw file was ignored, in
which case you need to use r.region to correct the map's position.
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
