I need to estimate the areas of a set of lakes for differente water height scenarios.
I am using the SRTM 30 DEM and I was hoping to apply r.fill.dir, to get the flow direction and water height for given heihg increments.
The documentation for r.fill.in stgates that "The procedure takes an elevation layer as input and initially fills all the depressions with one pass across the layer".
Unfortunately, there is no specification as to how tis is done. I have searched for the paper describign the algortihm on whihc r.fill.in is based "Software Tools to Extract Structure from Digital Elevation Data for Geographic Information System Analysis" by S.K. Jenson and J.O. Domingue (1988). but I have been unable to find it in the internet.
I need to ask two questions:
1) is there any other method you would reccomend in addition to r.fill.dir to compute water height/areas ratio for depresions using a DEM?
2) Anybody has a copy of the above cited paper or a detailed description of the algortuhm?
Cheers thanks
Armando Scalise
