[GRASSLIST:788] i.gensig quits
I am having trouble with grass "unexpectedly quitting" when attempting to run i.gensig or i.gensigset.
I have macintosh os10.4 with Lorenzo's April 8 installation.
This also happens occasionally when importing shape files.
I have swapped memory in and out to see if it is a result of bad memory, but there is not change in behavior.
Any ideas on what might cause this?
Thanks
Dave
On Thu, 20 Apr 2006 20:23:17 -0600
CLI or GUI? Any error, warning printed? If GUI and no error/warning
visible, try running the same command from CLI (GUI "hides" some
low-level messages from the user).
Same as above.
Maciek
Najwi?kszy serwis z og?oszeniami erotycznymi w Polsce, anonse erotyczne z
fotkami pa? i pan?w, serwis przeznaczony jest tylko dla os?b doros?ych.
www.anonseerotyczne.pl
I tried it from the command line and it worked fine.
Thanks
Dave
Same as above.
Maciek
On Fri, 21 Apr 2006 19:52:10 -0600
Good for you.
Can you now post your working CLI commands (i.gensig, i.gensigset,
v.in.ogr) which in GUI fail for you as you described earlier?
Any error/warning messages, or do the given GUI simply crashes, not
leaving any trace? Or maybe there is something printed to the console
subsequently?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
