[GRASSLIST:7910] grass-6.0.1RC2 compilation
I was trying to compile grass-6.0.1RC2 and had the following error log. The "./configure " worked before that.
I guess the problem is due to some libraries' path setting. I am fairly new to grass and any help will be appreciated. Thanks.
ubehebe:</scratch/grass6/grass-6.0.1RC2> make
mkdir -p /scratch/grass6/grass-6.0.1RC2/bin.sparc-sun-solaris2.9
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/bin
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/etc
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/driver
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/driver/db
mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/fonts
make[1]: Entering directory `/scratch/grass6/grass-6.0.1RC2/lib'
if [ ! -d /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include ]; then mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include; fi
if [ ! -d /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/vect ]; then mkdir -p /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/vect; fi
/afs/isis/depts/geog/pkg/ipw-1.0/etc/install -c -m 644 ../include/*.h /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/
install -- install commands, libraries, etc.
Usage: install [-c] [-m mode] [-o owner] [-g group] [-s] file destination
make[1]: *** [headers] Error 1
make[1]: Leaving directory `/scratch/grass6/grass-6.0.1RC2/lib'
make[1]: Entering directory `/scratch/grass6/grass-6.0.1RC2/db'
drivers
make[2]: Entering directory `/scratch/grass6/grass-6.0.1RC2/db/drivers'
dbf
make[3]: Entering directory `/scratch/grass6/grass-6.0.1RC2/db/drivers/dbf'
gcc -I/scratch/grass6/grass-6.0.1RC2/include -I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass -g -O2 -Wall -Wconversion -Wno-implicit-int -DPACKAGE=\""grassmods"\" -I/scratch/grass6/grass-6.0.1RC2/lib/db/dbmi_driver -I/scratch/grass6/grass-6.0.1RC2/include -I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass \
        -o OBJ.sparc-sun-solaris2.9/column.o -c column.c
        -o OBJ.sparc-sun-solaris2.9/cursor.o -c cursor.c
        -o OBJ.sparc-sun-solaris2.9/db.o -c db.c
db.c: In function `db__driver_open_database':
db.c:67: warning: passing arg 2 of `G_strchg' with different width due to prototype
db.c:67: warning: passing arg 3 of `G_strchg' with different width due to prototype
        -o OBJ.sparc-sun-solaris2.9/dbfexe.o -c dbfexe.c
dbfexe.c:22:22: shapefil.h: No such file or directory
dbfexe.c: In function `execute':
dbfexe.c:56: warning: passing arg 1 of `G_malloc' as signed due to prototype
dbfexe.c:207: warning: passing arg 1 of `calloc' as unsigned due to prototype
dbfexe.c: In function `sel':
dbfexe.c:474: warning: passing arg 2 of `qsort' as unsigned due to prototype
dbfexe.c: In function `eval_node':
dbfexe.c:496: warning: 'left' might be used uninitialized in this function
dbfexe.c:496: warning: 'right' might be used uninitialized in this function
dbfexe.c:501: warning: 'left_dval' might be used uninitialized in this function
dbfexe.c:501: warning: 'right_dval' might be used uninitialized in this function
dbfexe.c:501: warning: 'dval' might be used uninitialized in this function
dbfexe.c: In function `eval_node_type':
dbfexe.c:808: warning: 'left' might be used uninitialized in this function
dbfexe.c:808: warning: 'right' might be used uninitialized in this function
dbfexe.c:47: warning: 'cols' might be used uninitialized in this function
make[3]: *** [OBJ.sparc-sun-solaris2.9/dbfexe.o] Error 1
make[3]: Leaving directory `/scratch/grass6/grass-6.0.1RC2/db/drivers/dbf'
ogr
make[3]: Entering directory `/scratch/grass6/grass-6.0.1RC2/db/drivers/ogr'
gcc -I/scratch/grass6/grass-6.0.1RC2/include -I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass -g -O2 -Wall -Wconversion -Wno-implicit-int -I/afs/isis/depts/geog/pkg/gdal/include -I/afs/isis/depts/geog/pkg/tcltk/include -I/afs/isis/depts/geog/pkg/tcltk/include -DPACKAGE=\""grassmods"\" -I/scratch/grass6/grass-6.0.1RC2/lib/db/dbmi_driver -I/scratch/grass6/grass-6.0.1RC2/include -I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass \
        -o OBJ.sparc-sun-solaris2.9/describe.o -c describe.c
describe.c: In function `describe_table':
describe.c:79: warning: passing arg 1 of `G_malloc' as signed due to prototype
describe.c:85: warning: assignment discards qualifiers from pointer target type
describe.c:123: warning: assignment discards qualifiers from pointer target type
describe.c:116: warning: 'sqlType' might be used uninitialized in this function
describe.c:117: warning: 'size' might be used uninitialized in this function
describe.c:117: warning: 'precision' might be used uninitialized in this function
        -o OBJ.sparc-sun-solaris2.9/driver.o -c driver.c
        -o OBJ.sparc-sun-solaris2.9/error.o -c error.c
error.c: In function `append_error':
error.c:49: warning: passing arg 1 of `calloc' as unsigned due to prototype
error.c:51: warning: passing arg 3 of `fread' as unsigned due to prototype
        -o OBJ.sparc-sun-solaris2.9/fetch.o -c fetch.c
        -o OBJ.sparc-sun-solaris2.9/listtab.o -c listtab.c
        -o OBJ.sparc-sun-solaris2.9/main.o -c main.c
        -o OBJ.sparc-sun-solaris2.9/select.o -c select.c
gcc -L/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib -o /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/driver/db/ogr OBJ.sparc-sun-solaris2.9/cursor.o OBJ.sparc-sun-solaris2.9/db.o OBJ.sparc-sun-solaris2.9/describe.o OBJ.sparc-sun-solaris2.9/driver.o OBJ.sparc-sun-solaris2.9/error.o OBJ.sparc-sun-solaris2.9/fetch.o OBJ.sparc-sun-solaris2.9/listtab.o OBJ.sparc-sun-solaris2.9/main.o OBJ.sparc-sun-solaris2.9/select.o -lgrass_dbmidriver -lgrass_dbmibase -lgrass_sqlp -lgrass_dbstubs -lgrass_gis -lgrass_datetime -lnsl -lz -lsocket -lgrass_datetime /afs/isis/depts/geog/pkg/gdal/lib/ogrsf_frmts.a /afs/isis/depts/geog/pkg/gdal/lib/gdal.a /afs/isis/depts/geog/pkg/gdal/lib/ogr.a /afs/isis/depts/geog/pkg/gdal/lib/gdal.a /afs/isis/depts/geog/pkg/gdal/lib/cpl.a -lz -lm -ldl -L/usr/local/lib -lm -lstdc++ -L/afs/isis/depts/geog/pkg/tcltk/lib -ltk8.3 -lm -ltcl8.3 -lm \
        -lm -lnsl -lz
ld: fatal: library -lgrass_dbmidriver: not found
ld: fatal: library -lgrass_dbmibase: not found
ld: fatal: library -lgrass_sqlp: not found
ld: fatal: library -lgrass_dbstubs: not found
ld: fatal: library -lgrass_gis: not found
ld: fatal: library -lgrass_datetime: not found
ld: fatal: File processing errors. No output written to /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/driver/db/ogr
collect2: ld returned 1 exit status
