I have successfully installed GRASS6.0 on my system and have successfully added modified modules of
GRASS5.3 to GRASS6.0
But I cant find any d.label command in the GRASS6.0 source.
Is there no d.label command in GRASS6.0 ?
or is the name of that command changed.
Can anyone tell me?
Nagesh Bhatkar
Physical Oceanography Division
National Institute of Oceanography
India - Goa
On Tue, Aug 16, 2005 at 10:16:59AM +0530, Nagesh Bhatkar wrote:
Hello Everyone,
-> d.label - functionality pretty much covered by d.text
In GRASS 6.1-cvs I have updated v.label, d.paint.labels, and ps.map's
"labels" instruction to the point where I think it all works pretty
well. In 6.0 the above commands will work but setting font size, e.g.,
might be a pain.
Fine tune placement by tweaking the offsets in the labels file with a
text editor.
If no one else gets to it first I'll update the wiki when I return to
civilization in a few weeks time.
Is there anyalternative command to d.rast.labels ?
This isn't like d.rast.num or d.rast.arrow, but could be with a
r.to.vect + v.label step.
regards,
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
might be a pain.
text editor.
you:
me:
you:
Since d.rast.labels command isnt there in GRASS6.0 , as mentioned
above i used r.to.vect and the v.label command. The following was the
output
