Dear list,
please forgive me this stupid question ... but how can I convert a e00-file into a shape-file?
Greetings,
Tom
Thomas Zastrow
Seminar fuer Sprachwissenschaft
Universitaet Tuebingen
http://www.sfs.uni-tuebingen.de/dialectometry/
Wilhelm Str. 19
D-72074 Tübingen
Tel.: 07071/29-73968
Fax: 07071/29-5214
On 4/21/06, Thomas Zastrow <thomas.zastrow@uni-tuebingen.de> wrote:
how can I convert a
Try the avce00 library ( http://avce00.maptools.org/avce00/ ). It
contains a utility called 'avcimport' which will convert the e00 to a
arcinfo coverage. From there you can use ogr2ogr to convert to a
shapefile if needed:
avcimport input.e00 coverage
ogr2ogr -f "ESRI Shapefile" output.shp coverage/ arc
* The last argument of ogr2ogr is the layer name; 'arc' in the case of
lines, 'pal' in the case of polygons. I don't recall the layer name
for points but an 'ogrinfo coverage/' will give you a list of the
layer names contained in the coverage.
Matt Perry
perrygeo@gmail.com
http://www.perrygeo.net
how can I convert a
Matt Perry
perrygeo@gmail.com
Thank you, I've got it!!
Best,
Tom
Thomas Zastrow
Wilhelm Str. 19
D-72074 Tübingen
Fax: 07071/29-5214
