[GRASSLIST:7945] TIN export
Hello,
I want to export a TIN-DEM generated with v.delaunay. Is this possible with ESRI-shape output using OGR ? (The format generated by v.out.ascii and v.out.pov is not readable by the software I intend to use for further data optimization. If not ESRI-format a TIN-output in the following ASCII-format :
- header
- node-element-table
- node-location-table (x,y,z)
would be optimal)
Thanks in advance,
Karl
Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
