[GRASSLIST:7960] vector point sizes in meters in ps.map or display?
Dear GRASS Users,
I am having difficulties trying to print vector points at meaningful sizes (using Lorenzo Moretti's most recent 6.1.cvs on MacOS 10.3.9).
I have a vector point file with points corresponding to the peaks of conical mounds; mound diameters in meters are stored in the attached attribute table. I have successfully used ps.map to output the points to an .eps file, but is there any way to display or print the points so that their sizes correspond exactly to a value in the attribute table (mound diameters)? I see that d.vect.thematic can do something similar with graduated sizes or colors, but what about exact values?
If there is no way to do this, could someone point me in the direction of the presumably simple workaround of converting vector points to vector areas with new area diameters derived from the attribute table?
Many thanks in advance,
Chris Roosevelt
