Hello!
I tried to import a scanned map using the r.in.gdal module in the
following way:
I created a temporary x-y location larger than the scanned map, then
issued the "r.in.gdal input=filename ouput=nameofrastermap" command. It
results in segmentation fault. I tried to set the debug level higher,
but there are no other error messages.
The scanned map is in a jpg file. I have only read rights to this file,
but I don't think it's problem.
I use grass 5.0.3 version.
Any idea what could be the problem?
Thank you in advance,
Istvan
2005-08-23, k keltezéssel 09:33-kor Paul Kelly ezt írta:
Stefan Istvan wrote:
> Hello!
> following way:
Perhaps your gdal is linked to GRASS using the gdalbridge, which didn't
work with more recent versions of GDAL. You should recompile r.in.gdal
after re-running the configure script using the --with-gdal option, or
use a later version of GRASS where this is the default.
I've just installed Grass 6.0, and the problem disappeared.
Istvan
